Ansys Learning Forum Forums Discuss Simulation 3D Design Create an empty drawing sheet takes forever sometimes… Reply To: Create an empty drawing sheet takes forever sometimes…
Charudatta Bandgar
Sometimes larger assemblies could take time to work with, although this is too excessive. Can you try reinstalling SC? See if that helps, either it could be an issue with the installation.
Or clear the temp folder (run %temp%), and see if that helps.
Regards.
