Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Divergence detected during single particle deposition analysis › Reply To: Divergence detected during single particle deposition analysis
March 20, 2024 at 12:51 am
Diego Fernando Garcia Gonzalez
Hello rob,
The way I understand it, density is an intrinsic property , it isn’t clear to me when you’re referring “to scale fluid density”. Could you explain it to me?.
By the way, Initially I’m not monitoring the torque, I am mainly interested in being able to know the particle position and velocity during the fall. When I haven’t problems with the methodology, Imma estimate the Drag, Lift and Torque.
The divergence occurs from one moment to the next, I attach two images of the SixDOF solver history report where it’s possible to see reasonable results of the position of the Particle and after a while daft results until divergence.
BONUS: report oblate cylinder fall:
Regards.
