Ansys Learning Forum Forums Discuss Simulation Electronics Volume mesh is not conformal, hanging modes are found in the mesh. Reply To: Volume mesh is not conformal, hanging modes are found in the mesh.
GLUO
Could you rightclick mesh and go to the Advanced tab of initial mesh setting, check if you choose Flex meshing for TAU volume mesh? If yes, please uncheck the box and re-run.
GL
