Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Convergence problem › Reply To: Convergence problem
Odd this wasn't picked up by the checks on our side, possibly bumping after 12 hours mucked up the script.
You're adding more mass so it's possible the solver is picking up the greater source terms. How does the flow field look, and how does the particle mass & volume fraction compare to the fluid flow? Have you checked the fluxes, and how to the results look?
