Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About modelling the tube side flow as a solid cylinder › Reply To: About modelling the tube side flow as a solid cylinder
March 19, 2024 at 4:22 pm
Hi ,
I have attached a image of the centerline pressure contour ( I suspect the high value of pressure present in the inlet area , according to the literature i am following the value should be around 2351 Pa - a study done on a similar type heat exchanger) : I have conducted grid independence yet but I think thats the next step I am gonna do by decreasing the element size from 2mm and down.
Thanks in advance for any help you can offer to figure this error
