Ansys Learning Forum Forums Discuss Simulation Fluids Change Input File for user defined function in terminal in CFX Reply To: Change Input File for user defined function in terminal in CFX
CFD_Friend
Hi Christian,
If you are running a workbench file, then try pasting the input file (inlet profile file) in the user files folder inside the workbench files and point to the location in the CFX Pre location field for input profile. Now if you run this on Cluster, it will take the path automatically.
Or else if you are running CFX standalone, before copying the def files to cluster, in the CFX Pre, in the location field for the inlet profile just type in the name of the csv file.  Save the def file copy it to the cluster location and then copy and paste the input file in the same folder as the .def file in the cluster.Â
