Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About modelling the tube side flow as a solid cylinder › Reply To: About modelling the tube side flow as a solid cylinder
And contours on the centreline?  If you look for the button above the camera you can screen grab the results panel, saves posting pictures off your phone. The camera button saves the image to file.
