Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF error: member reference base type ‘void’ is not a structure or union › Reply To: UDF error: member reference base type ‘void’ is not a structure or union
Hi there,
Could you please elaborate what you mean by DPM summary example. As for the the Ansys Customer Support Space Registration Form, I don't believe I can get access to this in the relevant period of time.
As an update, the error message seems to be a result of the change in version of ANSYS Fluent being used (due to changes in the Fluent API between 2008 and 2023 versions). Any possible help regarding how to update the aforementioned part of the code would truly be appreciated! Many thanks for your time.
Kind regards,
Niall
