Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Ogden material models are used to show anomalies in LS-DYNA › Reply To: Ogden material models are used to show anomalies in LS-DYNA
Ram Gopisetti
When you see such error, the way to debug is to look into the mes* files or maybe d3hsp, Here, if you can post the solution information at last or post the error you are facing you might get better help from us or from community.
Cheers, Ram.
