Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About modelling the tube side flow as a solid cylinder › Reply To: About modelling the tube side flow as a solid cylinder
March 19, 2024 at 11:42 am
OK, so water, and water's density is pretty much constant for forced convection devices. Next step is to look at the mesh. Note, the outlet pressure you set, inlet is then calculated relative to that so please confirm you're comparing pressure relative to that with the same in the theory/experiment.Â
