Ansys Learning Forum Forums Discuss Simulation Fluids Dissolved Oxygen Simulation Reply To: Dissolved Oxygen Simulation
You will need to change the contents of the template, and make a second one for the liquid phase.  Re the phase composition, it's controlled by boundary conditions/patch and phase mass exchange. Not sure why you'd want a mass source unless you're coding up phase exchange yourself, in which case you may need some care with the mass transfer rates.Â
