Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About modelling the tube side flow as a solid cylinder › Reply To: About modelling the tube side flow as a solid cylinder
Ashen Perera
Hi , for the solid wall that separates the aluminum solid fluent properties  used (named selection is done to select the walls as the cylinder is not meshed ) , so basically for the fluid water properties (piece wise linear is used).
