Ansys Learning Forum Forums Discuss Simulation General Mechanical Parameters Set in static structural Reply To: Parameters Set in static structural
Chirag
Sir I applied the parameter in designmodeler, but it says in static structural user input is not defined but I defined user input in staic structural as pressure. Why it not considering as parameters? Same error is showing "DP 1) The Setup component in Static Structural for Design Point 1 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. "
