Ansys Learning Forum Forums Discuss Simulation General Mechanical Ansys Motion Function problem Reply To: Ansys Motion Function problem
Ankush Choudhary
Hi Hongxiao,
Yes, the E1 argument represents the independent variable, and it can also be an expression. Generally, in dynamic analysis, time is an independent variable. However, you can also use expression; it completely depends on your requirements and what information you need. I have tested the below function, which is working fine.Please test the below function expression.
STEP(WZ(#1,#2),-1*126/180*PI,1,126/180*PI,-1)*(0.535*AKISPL(ABS(FZ(#1,#2)),0,#3,0))+AKISPL(SQRT(TX(#1,#2)*TX(#1,#2)+TY(#1,#2)*TY(#1,#2)),0,#4,0)+8.78
