Ansys Learning Forum Forums Discuss Simulation General Mechanical Multi load step analysis in apdl from workbench Reply To: Multi load step analysis in apdl from workbench
mrife
No - WB Mechanical does not write out the MAPDL post processing commands generally.  It does write out some to gather some solution statistics.  But the post-processing in WB Mechanical is being done by WB Mechanical.
If you want to post process in Mechanical APDL interactively you need to learn how to use MAPDL.  Normally universities that offer Ansys products have the help installed somewhere/somehow so that the students can access it (the help).  It may be installed on each computer in some lab.  Or maybe accessed via a department web site.
So...does your school have a computer lab with Ansys installed?
