Ansys Learning Forum Forums Discuss Simulation General Mechanical Errors with Topology Analysis Reply To: Errors with Topology Analysis
Daniel Barvenik
Hi Ashish,
Unfortunately no.  Following that link, Nanda Veralla suggests to:
  1. Go to the Start Menu and open %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’ then launch the application.
  2. Open a file explorer and type %appdata% in the address bar.
     Locate the Ansys folder --> select version (V231) and rename it to V231.old
I did #1 but when tried #2 I could not find an ansys folder in appdata.
So I tried rerunning it after renaming .ansys to .ansys.old, but same error.
I am using 2019 R3 by the way.
I then followed Gary Stofan's link that is linked on that site.  I tried retaining design points.  I went to "Tools > Options > Appearance…scroll down to “Beta Options” and check the box".  Then made some parameters like maximum stress and followed the instructions to retain design points.  But that didn't help.  Same error.
I also did not find a file with the name ansyswbdumpfile.dmp.
Still looking for help getting this basic run to work!
