Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › contact between two perpendicular shell plates › Reply To: contact between two perpendicular shell plates
March 18, 2024 at 4:47 pm
I suggest that flange and web share nodes at their juncture even though it means there's some slight overlap of material at that juncture.   *CONTACT_AUTOMATIC_SINGLE_SURFACE would only be needed if deformation were extremely large, such as would occur if the section buckled.
If that doesn't help, provide an image that illustrates the bad behavior.
