Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ls-dyna dynamic relaxation. › Reply To: Ls-dyna dynamic relaxation.
March 18, 2024 at 4:37 pm
Jim Day
That means the distortional kinetic energy is continuing to increase, perhaps because the applied load is still increasing?  You should ramp up the load with a fairly short ramp time and them hold the load constant.  You should see convergence reduce at some point after the full load is applied.
