Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pitching airfoil using overset and dynamic mesh. › Reply To: Pitching airfoil using overset and dynamic mesh.
Federico
Since you are using Overset, I believe you need to set the motion to the entire moving fluid cell zone. You can use Display Zone Motion in the Dynamic Mesh task page to check if the movement is set up correctly before running the case.
