Ansys Learning Forum Forums Discuss Simulation Fluids Stabilizing pressure message Reply To: Stabilizing pressure message
Federico
This is only a warning. If you find the message only appears in the first few iterations and goes away, you might be Ok to just ignore it. If the message persists, than it could indicate that your solution is not stable.
