Ansys Learning Forum Forums Discuss Simulation LS Dyna Running more simulations at a time and extract results without manually opening Reply To: Running more simulations at a time and extract results without manually opening
armin.abedini
Hi Jaswanth,
If you're using LS-PrePost for post-processing your model, it is possible to use macro commands to automate the process. Please look up online for "LS-Prepost Command Line Interface" and you should be able to find some resources online.
https://lsdyna.ansys.com/command/
