Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded › Reply To: An internal solution magnitude limit was exceeded
March 18, 2024 at 12:18 pm
You must make sure that the nodes of the beams are connected to each other, in Design Modeler you must place all the elements in a new part. In Space Clein you must activate share topology.
