Ansys Learning Forum › Forums › Discuss Simulation › Fluids › AQWA-FER failed to Converge for Configuration/Spectrum › Reply To: AQWA-FER failed to Converge for Configuration/Spectrum
Shuangxing Du
Please read Aqwa theory manual, 14.1 Effective Nodal Acceleration RAOs for the effective acceleration definition in Aqwa.  "accelerations+g" is not the effective accelerations from AQWA.
Please check your defnition of non-linear roll damping using the bilge keel properties, which may cause the linearization iteration failure.
