Ansys Learning Forum › Forums › Discuss Simulation › Fluids › AQWA-FER failed to Converge for Configuration/Spectrum › Reply To: AQWA-FER failed to Converge for Configuration/Spectrum
Hi sxdu, thanks for your response.
Yes, you are right, but the thing is the axis direction is the same in both octopus and aqwa, just the location is different. The accelerations on the vessel COG are the same, and the normal accelerations on the cargo are also the same, but the issue is with the effective accelerations. The effective accelerations are very different. What can be the reason here? (I am assuming that the effective accelerations are the ones including the static component of gravity, so I am comparing the effective accelerations from AQWA with the "accelerations+g" from Octopus.)
Moreover, I have not defined any drag or Morison coefficients. I have used non-linear roll damping using the bilge keel properties.
