Ansys Learning Forum Forums Discuss Simulation Fluids About modelling the tube side flow as a solid cylinder Reply To: About modelling the tube side flow as a solid cylinder
OK, there are a few options.
  • Heat source in a solid (meshed) tube
  • Heat flux/temperature/convection on the "other" side of the tube wall
  • Heat flux/temperature/convection on the wet side of the tube bounding the shell side fluid
All are valid, I'd probably go for convection on the wet wall, as that minimises the mesh requirements and probably good enough with some care.
