Ansys Learning Forum Forums Discuss Simulation Fluids Forced Convection Reply To: Forced Convection
Atharva Nagarkar
Hello Ella,
Please find the link below to an Ansys Course on setting up a turbulent forced convection problem. This course should act as a guideline for you to setup a forced convection problem. You may have to adjust some parameters and settings based on your case.
Turbulent Forced Convection | Ansys Innovation Courses
Additionally, I am attaching a link below from the Ansys User's Guide regarding forced convection. Please check the different sections if applicable.
15.2. Modeling Conductive and Convective Heat Transfer (ansys.com)
If you are not able to access the links, please refer to this forum discussion: Using Help with links (ansys.com)
Thanks!
