Ansys Learning Forum Forums Discuss Simulation 3D Design simulation problem Reply To: simulation problem
Charudatta Bandgar
Hello Sidhaan,
Are you using a faceted geometry for the simulation? Can you convert the faceted geometry into a solid, and do the simulation on that? Currently the capabilities with faceted geometry are limited in Discovery.
I am guessing the questions mentioned below are on same topic, being duplicated. We will continue the conversations here.
1. external fluid flow and and facet problem (ansys.com)
2. facet problem and fluid flow problem (ansys.com)
3. simulation and facet problem (ansys.com)
