Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Encountering some problems using Maxwell Optimization › Reply To: Encountering some problems using Maxwell Optimization
March 17, 2024 at 2:43 am
3. To view cost values versus completed iterations in data table format, you can right-click the optimization setup for which you want to view the cost results, and then click View Analysis Result on the shortcut menu. The Post Analysis Display dialog box appears. Under the Result tab, select Table as the view type. The cost value at each solved design variation is listed in table format.
