Ansys Learning Forum Forums Discuss Simulation Electronics Encountering some problems using Maxwell Optimization Reply To: Encountering some problems using Maxwell Optimization
GLUO
2. In the Maxwell Optimization variable tab, the Min Step and Max Step are used to define the step size for the Quasi Newton and Pattern Search optimizers. The step size is the difference in a variable's value between one solved design variation and the next. This step size is determined when Optimetrics locates the next design variation that should be solved in an effort to meet the cost function.
