Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Is it possible to manually set end winding for MAXWELL 3D motors? › Reply To: Is it possible to manually set end winding for MAXWELL 3D motors?
GLUO
You can check the templates in Draw>>UDP>>Rmxprt and modify the parameters to create a model close to your design, otherwise you have to use the geometry operations to create the end winding manually and unite it with the conductor bars. If you are interested, Motor-CAD can generate 3D Maxwell model directly.
GL
