Ansys Learning Forum Forums Discuss Simulation Optics Optimizing EO Effect: Analyzing Static E-Field Distribution Reply To: Optimizing EO Effect: Analyzing Static E-Field Distribution
Guilin Sun
The data is not sliced. instead, it is from the finite element meshing that makes it 1D. You will need to interpolate it into 2D graph:
interptri - Script command
it has example script file for reference.
