Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Multi load step analysis in apdl from workbench › Reply To: Multi load step analysis in apdl from workbench
March 15, 2024 at 6:51 pm
mrife
Hi OmobolajiÂ
In the input file there is a *IF condition at the end of load step 1 that if MAPDL is running interactively the /EOF (end of file) command is read, otherwise the SOLVE command is issued. You can edit the input file and take out the whole *if/*endif construct and just leave the solve command. Or copy the second load step commands and paste them to the command window in MAPDL interactive to do the second load step (after the first completes solving!).
MikeÂ
