March 15, 2024 at 4:52 pm
andrew o'sullivan
I can make the airflow steady state if it will work with the particles better, I presumed the airflow dispersing and being extracted by the return ducts counted as being transient. Is it possible to set a velocity parameter for the return air ducts, so the air is extracted at a given velocity? You think I should remove the doors/windows from the model completely?.Â
