Ansys Learning Forum Forums Discuss Simulation Electronics The peak spatially-averaged SAR over 1gr or 10gr of tissue Reply To: The peak spatially-averaged SAR over 1gr or 10gr of tissue
Nooshin Valizade Shahmirzadi
Thank you for your reply. I have a couple of questions which arise from your reply. Is peak spatial averaged SAR over 1gr or 10 gr of tissue the value that I have to compare with the value recorded in the safety code or I have to consider the certification SAR through field calculator? I reviewed the HFSS PDF file on SAR calculation however I didn't quite understand which calculation method is the one that I have to use for my comparison.
Moreover, I couldn't still solve my warning issue in certification SAR calculation. I am using (“Academic Research” bundle) through CMC microsystems, so how can I contact your technical support to provide them with my simulation file?
Kind regards,
Nooshin
