Ansys Learning Forum Forums Discuss Simulation LS Dyna A question about the Stiffness Type in Coupling Reply To: A question about the Stiffness Type in Coupling
Ian Do
Hello Tomas,
From the manual:
"PFAC
LT.0: PFAC must be an integer, and -PFAC is a load curve ID.
The curve defines the coupling pressure on the y-axis as a
function of the penetration along the x-axis. See Remark
6. See “How to correct leakage.”
6. PFAC < 0 for CTYPE = 4, 5, or 6. PFAC < 0 refers to a load curve. This curve
may be constructed with the x-axis as the penetration distance (in absolute
length unit) and the y-axis as the maximum estimated coupling pressure. This
curve requires only 2 points. The first point is (0.0,0.0) because no FSI pressure
applies when no penetration occurs. The x-value for the second point is 10% of
the minimum ALE element width, and the y-value is the to be determined maximum
observable pressure in the ALE domain. To determine this y-value, run
the model once with PFAC = 0.1 (the default). Then, select only the ALE domain
and plot its pressure fringes. Next, step through time to identify the maximum
pressure in the ALE domain, selecting the pressure peaks at or near the FSI surfaces.
This maximum pressure becomes the y-value of the second point."
Ian Do
