Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Opening a second pressure outlet time-delayed during simulation via UDFs › Reply To: Opening a second pressure outlet time-delayed during simulation via UDFs
Have a look at the various courses in Learning, and also the tutorials in Help.
Re the sample, do you want to set a pressure, or fixed flow out of the domain? Sketch out the model along with all known (and needed) data to better understand what you want from the model. Ie treat simulation as you would an experiment.
