Ansys Learning Forum Forums Installation and Licensing Ansys Products AQWA, The displaced volume is twice the actual volume Reply To: AQWA, The displaced volume is twice the actual volume
Shuangxing Du
Please check your geometry:
(1) only external hull surfaces are defined;
(2) the normal directions of the surfaces points towards the external water.
(3) the spart platform is at the correct position related to the still water level.
