Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › create parameter for thickness in spaceclaim sheetmetal › Reply To: create parameter for thickness in spaceclaim sheetmetal
March 15, 2024 at 12:23 pm
Hello Miguel,Â
Its not possible to parametrize the thickness of the Sheet metal from the options shown below in the properties panel:
You can refer the Using a Bend Deduction Table where you define combination of Thickness and VeeDieWidth like one shown below:
Although this is for bend radius and not directly for thickness. Comma-Separated Value FileÂ
Another way could be to create a mid-surface and assign a thickness to it in Mechanical. Let me know if this helps.
Thanks,Â
Devendra
