Ansys Learning Forum Forums Discuss Simulation General Mechanical How can I connect rebar and concrete ? Reply To: How can I connect rebar and concrete ?
Aurojyoti Prusty
You can just add your steel rebars as line bodies and then use a reinforcement without any contact definition using the reinf264 elements.
You may refer the below link for more information.
Contact modeling for Steel rebars in Concrete using Ansys workbench
/forum/forums/topic/contact-modeling-for-steel-rebars-in-concrete-using-ansys-workbench/
Hope this helps.
Thanks
Aurojyoti
