Ansys Learning Forum Forums Discuss Simulation General Mechanical MAPDL convection load with variable film coefficient and bulk temperature Reply To: MAPDL convection load with variable film coefficient and bulk temperature
dlooman
I didn't want you to include any of the other commands in the cut and paste.  Just the table definition.  After cutting and pasting them in you need to pick on Parameters in the top tool bar and then Array Parameters > from the drop down menu.  Then Define/Edit.  You should see you array name in a list that you can pick on.
