Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Hydraulic fracturing Simulation using FSI › Reply To: Hydraulic fracturing Simulation using FSI
You can post-process the results of coupling analysis by opening results in participant solver or ensight to determine the fracture dimensions. Postprocessing System Coupling's Co-Simulation Results (ansys.com)
The System Coupling option must be selected on the desired moving and deforming wall boundaries in order to obtain displacements from other co-simulation participants taking part in the coupled analysis. 42.5. System Coupling Related Settings in Fluent (ansys.com)
I recommend going over this tutorial in the Ansys documentation that shows a 2-way FSI simulation with Fluent and Mechanical. Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical) (ansys.com)Â
You can also look at the following for a similar tutorial but run with the System Coupling GUI outside of Workbench. The new System Coupling GUI (run outside of Workbench) is available by searching for System Coupling 2019R3 (or newer) in the Windows Start menu.
FSI simulations with very soft materials or membranes are prone to numerical instabilities. In 2020R1 we have introduced a stabilization method in System Coupling called the Quasi-Newton Stabilization Algorithm. Note that this has to be used with the new System Coupling GUI or Command Line Interface that is run outside of Workbench. More information here:https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/sysc_ug/sysc_gen_scservice_dt_supplemental_iqnils.html
It is very important to build up the FSI simulation in stages as opposed to setting up the 2-way FSI right at the start. This document Best Practices for Coupled Fluid-Structure Interaction (FSI) describes this process and is available here:Best Practices for System Coupling (ansys.com)
