Ansys Learning Forum Forums Discuss Simulation Fluids Holes in mesh Reply To: Holes in mesh
Federico
The Mesh Check does not report any error, so this is a good sign.
In Fluent Meshing, clicking on the Surface Mesh task in your Outline view, you should then be able to Check Surface Mesh quality.
Please report the Maximum Skewness and Minimum Orthogonal quality, as these are better indicators than averages.
