Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DO method for Radiation Heat Transfer › Reply To: DO method for Radiation Heat Transfer
Hi,Â
Thank you for replying. The angle between window is 90 deg. So, I put the theta = 90 and phi = 0 in Beam width. Did I put the correct values? Also, I clicked the "Apply Direct Irradiation Parallel to the Beam". So does it depend on the beam width values?Â
In below Ansys guide, It is mentioned "The default beam width in ANSYS FLUENTÂ isÂ
degrees which is suitable for collimated beam radiation". I could not understand the logic of 1e-6.
https://www.afs.enea.it/project/neptunius/docs/fluent/html/th/node115.htm
In below picture, It is showing both theta and phi are divided by 2. So if I gave 90 then should I give 90/2=45? Please guideÂ
Thank you.Â
