Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Help with Contacts between both Shell and Solid Parts › Reply To: Help with Contacts between both Shell and Solid Parts
Sampat Kumar
Hi
For the first contact issue, you can try using edge-to-edge contact and see if this works or not. You can use the MPC too.
For the second question, it seems the face selected for the contact body is the upper face, it should be the bottom face of the plate.
Best Regards,
Sampat
