Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Missing options for pulverized coal combustion section settings › Reply To: Missing options for pulverized coal combustion section settings
March 14, 2024 at 10:22 am
Stemphanie_anansu
Use the following steps to simply perform the test:
1. active energy
2、active ke
3、active P1
4, active edc and select coal hv volatile air as material
5, active discrete phase, set injection, select combusting particle.
There is no option for these two parameters in the interface under material under combusting particle.
May I know where else I need to set it? Is there any parameter that has been canceled or omitted?
