Ansys Learning Forum Forums Installation and Licensing Ansys Products Unable to acheive anticipated Static and Total Pressure Values Reply To: Unable to acheive anticipated Static and Total Pressure Values
Essence
But you mentioned you are carrying out an external flow simulation. That's why I recommended pressure-farfield BC. Could you indicate which is the nozzle in your model? It would be helpful if you share the picture, where the inlet, outlet, walls and other BCs are displayed properly. And as the FMG is concerned, you need to bring down the Courant number to ensure the shock wave travels till the outlet.
