Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unable to acheive anticipated Static and Total Pressure Values › Reply To: Unable to acheive anticipated Static and Total Pressure Values
Thanks for responding , Y+ is around 3.3, after i added boundary layers, i will reduce it down to less than 1.
I tried fmg initialization after you had mentioned, it says something like this:Â
temperature limited to 1.000000e+00 in 208 cells on zone 2
temperature limited to 1.000000e+00 in 20 cells on zone 2
temperature limited to 1.000000e+00 in 6 cells on zone 2
temperature limited to 1.000000e+00 in 4 cells on zone 2
FMG: Converge FAS on level 5
FMG: Converge FAS on level 4
FMG: Converge FAS on level 3
FMG: Converge FAS on level 2
FMG: Converge FAS on level 1
0.
Reversed flow on 18 faces (100.0% area) of pressure-outlet 5.
Reversed flow on 32 faces (100.0% area) of pressure-outlet 6.
time step reduced in 66 cells due to excessive temperature change
for the pressure-farfiled BC, I can only give mach 0, would that be a logical thing to do? Because, i only have a subsonic flow at the nozzle with a mach of 0.59. but the Pressure-farfield BC sets the entire domain to a mach, i am not sure about that.Â
