Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Variation of outputs from MotorCAD to Maxwell › Reply To: Variation of outputs from MotorCAD to Maxwell
MirandaH
The current should be close between Maxwell and MotorCAD, could you compare an example from MotorCAD with exported Maxwell? Are the results close with example file on your end?
