Ansys Learning Forum Forums Discuss Simulation Photonics Arbitrary sign for eigen mode Reply To: Arbitrary sign for eigen mode
Guilin Sun
Unfortunately the seeds for FDE are random and might be machine dependent. and the back propagation modes are also physical. I could not duplicate your result:
what OS version you are using?
You may try to disable the "rand", or reset it like this:
?randreset();
I do not see the necessity here using "rand".
I tested your script. with randreset as well as disabled "rand", they all give the same result on Win11:
We need to duplicate the issue if it is a bug.
