Ansys Learning Forum Forums Discuss Simulation Electronics RMXPRT models: difference between “Standard”, “General” and error in materials Reply To: RMXPRT models: difference between “Standard”, “General” and error in materials
Manes Fernandez Cabanas
Thank you very much Miranda,
Since I wrote the post I have been working with both types of machines, I am sorry to have bothered you because my problem came from an error in the way of assigning materials that I could not see, not having opened the Message Manager. I was left wondering about something that I have not been able to check yet. According to the manual: "You can select either Maxwell Model Wizard or Generate RMxprt Solutions. If Maxwell Model Wizard is selected, you can create an RMxprt design aimed for Maxwell design creation only". I don't want you to waste any more time, please, just one line is enough. I always used RMXPRT when the product was from Ansoft and as far as I can see now, the export of the geometric model to Maxwell is straightforward. Is there any change if the workflow starts with the selection of Maxwell Model Wizard? Sorry to ask you the question, but the set up, server installation, licensing, etc. for my Electrical Engineering Degree students got so far behind that I am working with them at the same time I am adapting to the new program.
Thank you really, you have been very kind ????.
Manés
